ABS Pump
Hi all
Have just had the car back from the dealer who was checking out a TRAC / ASC warning light.
They initially thought it was the nearside wheel speed sensor & harness which they changed - for $384.88 + tax (:-0). Light stayed on. OBD reported C1095 - something to do with the pump motor circuit.
They say it may be a false negative since they did a hard reset & the light went out, but they explained something to me about pump motor resistance. It went something like this...(transcribed as well as I recall)..
A new ABS pump motor would provide 0.7ohm resistance, mine was 3ohms
A new ABS pump motor voltage with key off would be 4.67v, mine was 1.07v
A new ABS pump motor voltage with key on would be 7.96v, mine was 7.96v
I'm told everything is OK & that everything is safe, but to go see them again if the light comes back on.
Any thought's?
Jof
Any thought's?
Jof
ericjansen
12-19-2021 12:20 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
xjrjag
09-24-2015 10:08 PM
