ABS and Stability control fault
If you do a search you will find extensive information here. Yes, they are connected. Below is a starting point.
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Unless you find some one to read the ABS codes, you will shooting in the dark.
Davebc (08-28-2013)
I am missing ALL 3 of the fuses it says to check in the boot fuse box.
In the Jagrepair photo the fuses have big yellow pieces on them, what kind of fuses are these?
And after further inspection of those three empty fuse bays, there is nothing underneath them, there is nothing for them to slide into and connect to, does this make sense?
I technically do have a 5 fuse on the fourth slot on the RIGHT side of the box, not sure if that is supposed to be there or not? ( this one is fit into the fuse connector and is tight in place )
The picture you posted yesterday was of the fusebox in the trunk, not the fusebox under the hood. The ABS fuses are in the fusebox under the hood.
Sorry for being so clueless, all three of those fuses are perfectly fine.
Should my next step be getting the codes read or finding someone who can do what is described in the TASK on that link regarding disconnecting the ABS multi plug from ABS controller ETC?
Will any of the chain stores be able to read these type codes?
