ABS and Stability control fault
+1 on getting a scan done ASAP. $50+/- at the dealer! Worth it, keep you from tearing your hair out! lol
If you get the urge to get your hands dirty right now, lots of info on forum on some things you can have a "stab" at including:
Cleaning your ABS sensors
Check all ABS sensor wires are plugged in and secure
Check sensor wires have enough free play at front wheels (Mine didn't and tugged at plug-in, slight interuption in connection caused the fault to show)
Check wiring securely connected at ABS module
All pretty simple things to do yourself, only need 8mm wrench/spanner and toothbrush! Here's a link with more info on sensor cleaning also has a great video from Rev Sam
https://www.jaguarforums.com/forum/x...idding-101353/
I had the ABS fault/ DSC fault for OVER A YEAR before I went to dealer for scan, save time and hair!
Good Luck
Good Luck
Last edited by Davebc; 08-28-2013 at 04:13 PM. Reason: Added link re cleaning sensors
Yup around the $50 CAD mark plus the taxes of course. Got a print out too. went in specifically to find out what was causing the ABS fault DSC fault.
Definitely worth the money if it leads to a solution. I even took out ABS module and disassembled it to check the solder joints only to find my MY is not affected by the cold solder cracking the earlier models did. I wasted a lot of time poking around trying to fix the problem before I really knew what the problem was~time I could have been driving the car or sitting on the beach with my honey!
Thankfully someone on this very forum suggested I get the codes read. I did!
RJ237 suggested getting codes read in post 2~awesome advice.
Yes, a bad wheel bearing could be causing your abs woes also (speed sensor on the offending wheel) but get the code(s) read for sure to determine true cause(s)
ericjansen
12-19-2021 12:20 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
