ABS and TRAC warning light
This is the second time you've posted the same question in Jaguar Forums Feedback & Suggestion Center forum. The Jaguar Forums Feedback & Suggestion Center forum is NOT for technical questions, it's for posts about the forum.
I've moved your question to XK8/XKR forum.
Your previous post was also moved to XK8/XKR forum where it received some good advice:
https://www.jaguarforums.com/forum/x...ilable-140779/
When the ABS and TRAC not available message appears it is advising that ABS and TRAC are not operating. The vehicle will handle as if these driver aids were not fitted.
jhennigar1 (10-30-2016)
Search for C1095 ABS fault.
The JEPC replacement part number for your car is JLM21323.
The number on the ABS module housing will NOT be that number.
bob
This particular fault can also be caused by dirty wheel speed sensors. You remove them (one 8mm bolt) and scrub them with a dish soap and water mix using an old toothbrush. Let them dry before you re-install them. Reverend Sam posted a video a number of years back showing how to access, remove, and scrub them....
Check the condition of their wiring harnesses while you're there. The harness insulation tends to degrade which allows rainwater ingress into the wiring and can also cause these faults....
The following 2 users liked this post by Jon89:
gelair (01-04-2017),
The following 2 users liked this post by pbuck:
