abs traction control fail and stability control fail continuing
HI guys,
I have this problem on starting the car up. I have read the other posts on this and removed and cleaned all sensors and replaced the driver side abs sensor but the problem is still occuring. Revernd Sam had a link to check the solder points but this link no longer seems to work so I havent been able to try that.
Has anyone anymore idea on what the problem could be?
Thanks in advance
Adrian
Thanks in advance
Adrian
http://jagrepair.com/images/AutoRepa...e%20Repair.pdf
Try this one. You can also send the module out for repair for a little over $50. Do a search on the forum also, someone effected the repair by drilling a hole in the case and soldering the posts.
RJ____________________
97 XK8 86K mi
97 XK8 86K mi
There's a link in the HOW TO in this section
https://www.jaguarforums.com/forum/x...ts-data-29800/
Scroll down to alphabetic list and it's the first item
