ABS, traction, stability trivia
I bought my 97 XK8 last spring and it always showed ABS, traction control, stability control error. I was planning on going over the fixes some day but was in no real hurry. I noticed that as the, Michigan, outside temperature began to fall into the 30's that the errors started going away. Warmer days the errors came back. Colder days the errors weren't there. Interesting. Any ideas?
have to be very careful splitting the case for the money involved id use the place in ca. they send you an abs module you swap yours out for it and send yours back if it can be rebuilt they refund the core charge. its very touchy to do the resolder your self . place i used is called module repair pro on ebay .
The most difficult parts of the fix were 1. moving the brake lines out of the way-had to disconnect all, and 2. sawing the edges of the module to get through the adhesive. I don't think much air got into the lines when disconnected, as fluid was at the top of each circuit, and minimal fluid came out of the lines. Be sure to quickly reattach them when you get the module out. To saw through the adhesive holding the module together, I used a small hand saw. After I soldered the contacts and reassembled everything, the messages went away immediately. They then reappeared a few days later. They still come and go. I was told it could take up to several hundred miles before the messages are permanently gone.
If you have access to a drill press, boring a hole in the case opposite the pins is less risky and neater. But don't use a pilot drill.
JagRepair.com - Jaguar Repair Information Resource
in my case they never went away after 2 months as for the lines you can wiggle and bend them out ot the way just use gentle pressure and a long extension as a pry bar to slide the lines enough to wiggle out the module .disconnect the module first as when you start moving the lines you will block the point where it disconnects at .
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
