AC Compressor issue 2001 XK8
Hi guys, I have the 2001 XK8. The compressor finally wore out and I replaced it with a used one. The compressors are identical and has been installed. The newer one has a "pressure sensor on it which my original one did not. I do not have a plug in my harness for the pressure sensor and it will not kick on. Does anyone know if there is a plug I can add to power the compressor, or a bypass fitting that will allow the compressor to run normally with out the sensor connection? I would hate to have to take it off and install another on. Any suggestions would be appreciated.
Brian
Brian
slownlo
06-10-2017 08:12 PM
john_cook12
08-10-2016 11:37 AM
