AC not very cold or "dry" thoughts
Old 06-23-2016, 09:02 AM
fmertz's Avatar
Received 1,503 Likes on 1,052 Posts
Originally Posted by TreVoRTasmin
24 Face vent demand potentiometer fault Potentiometer open / short circuit Harness / connector
fault Refer to PDU
For some reason, a while back, I looked for a face dash vent on eBay. I am talking about the black hard plastic part with the vanes and the (mechanical) wheels on each end. Or so I thought.
Turns out, best I can figure, that some cars also came with a center wheel, seemingly with a hot/cold wheel (with an electrical connection).
In your case, I would try and do a bit of research to find out if your car is supposed to have this adjustment wheel, and whether you actually have it or not. Also, this wheel is supposed to be connected to the HVAC control module, so I would check that, too. Maybe the plug is just hanging, or a prior owner just swapped it out and never bothered with the plug. The electrical manual would be a good place to start for hard data.
Best case scenario, when this connector is off (which is what I believe this error code is telling you), the system defaults to "heat", meaning you have nice dry air from the A/C, but it is also warm because the system brings hot water into the heater core as well. Plugging this in into the right kind of vent would probably fix the problem.
Just my thoughts.
Best of luck, keep us posted.
Dash vent with 2 wheels
Dash vent with 3 wheels
Jon89 (06-23-2016)
Old 06-23-2016, 09:07 AM
Jon89's Avatar
Received 4,358 Likes on 2,849 Posts
Very interesting, and thanks for the difference-in-vents lesson....
KayScotts
05-08-2016 04:16 PM
micmee1
04-11-2016 03:40 PM
darrhel
04-09-2016 04:30 AM
daves_ale
04-03-2016 07:46 PM
Travis O'Gallagher
04-03-2016 02:49 PM
Quick Reply: AC not very cold or "dry" thoughts
