AC recharge valve location
Old 04-23-2016, 05:40 PM
willtoliv's Avatar
Default AC recharge valve location
1998 XK8. Where is the low side AC charge valve located? I am in need of a charge refresh.
Thanks!
Old 04-23-2016, 05:54 PM
GGG is offline
Received 16,866 Likes on 12,186 Posts
See item 8:
The following 2 users liked this post by GGG:
Johnken (04-23-2016), Orthodixie (12-04-2018)
Old 04-23-2016, 06:09 PM
mrplow58's Avatar
It is in the right side of the engine compartment, just above the engine, and below the cowl.........Mike
The following 2 users liked this post by mrplow58:
Old 12-03-2018, 02:58 PM
ednaiken's Avatar
Default Cap size
Originally Posted by GGG
See item 8:
Does anyone know what size the cap is for the low pressure port? I dropped the damn cap and it went hiding somewhere under the engine. I have seen 13mm caps for sale...would this be the size??
Old 12-03-2018, 06:47 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
The low pressure and high pressure ports are all the same size for all R134 systems. The small cap is low pressure and the large cap is high pressure. 13mm sounds like the size for the low pressure port.
Dang
06-24-2019 03:52 PM
Salu498
04-23-2016 03:13 AM
Bcrary3
04-22-2016 02:44 AM
agd
04-21-2016 05:56 PM
magmedia
04-18-2016 05:31 PM
Quick Reply: AC recharge valve location
