Accessory Drive Belt?
From the Workshop Manual:
5. Detach the accessory drive belt.
1. Rotate the accessory drive belt tensioner counter-clockwise
1. Use a 3/8 inch square drive bar to rotate the accessory drive
belt tensioner.
2. Detach the accessory drive belt
6. Reposition the accessory drive belt tensioner.
1. Loosen the accessory drive belt tensioner retaining bolt.
2. Reposition the accessory drive belt tensioner.
7. Remove the accessory drive belt.
I don't get Step 6. Why and where do you reposition it?
belt tensioner.
It's just a standard spring loaded belt tensioner, nothing fancy. One thing that helps with the SC belt is removing the two little nuts holding the radiator fan bracket and having someone hold that up about an inch or two while you get the breaker bar in the square hold on the SC belt tensioner.
petemohr (03-26-2019)
Received 2,380 Likes
It looks like the intention is that by loosening the pivot bolt, the tensioner assembly locating pegs can be pulled clear to allow the whole thing to be rotated anticlockwise.
I can't find a picture of the front of the 4.2 motor:- is this to give more room to remove the belt since it passes behind the tensioner arm on the later cars?
