Accessory Supply Socket in Boot
The following 3 users liked this post by Gus:
it's the Black connector to the right of the photo. Black wire is Ground, Brown/Green wire is permanent live and White/Red is ignition switched live.
For the switched live, you'll need a standard relay in the centre position of the three relay sockets lined across the car in the Trunk Fuse Box and a 20A fuse in F11 of that fuse panel.
For the permanent live there's a 10A fuse in F17 in the Driver's side fuse panel.
The following 5 users liked this post by astromorg:
GGG (02-26-2018),
jimmiejag (03-03-2018),
Johnken (02-25-2018),
michaelh (02-25-2018),
Pristine97XK8Convertible (02-25-2018)
Thank you so much astromorg for your detailed description.
Now I realize the Accessory Supply Socket is meant to be used in conjunction with part number C2A1403 Auxiliary Power Socket which comes with various socketed cable harnesses and what is essentially a cigarette lighter socket with spring-loaded cover. I understand C2A1403 is no longer available, so we have to do some wire cutting and splicing.
Just to make a small clarification on the wire colors:
Cheers !
- B Black
- NLG is Brown w/LightGeen
- PN is Purple w/Brown
Cheers !
Pristine97XK8Convertible (02-28-2018)
