Accidental reverse polarity while trying to jump start a flat battery
Update
UPDATE:
Thanks for all the help. I now have the car back on the road and seem to have got back to full function without any major damage. I could not manage to figure our which terminals of the diodes for multimeter test.
In case this happens to anyone else, my experience of reverse polarity jump start from a running similar car applied to a dead battery on an XJ8 was blown fuses in both kickboards and in the boot. None blown in the engine fuse box. Hopefully no damage.
Elfresh (05-19-2016)
I like these,,, Because there might not ALWAYS be willing Jumper when you need them the most... And if you do reverse the polarity and screw their car up,,, Now you have a bigger problem... which neither of you can drive away from...
So check this out or something similar
1000 Peak Amp 12 Volt Battery Booster Pack Jump Starter Pac With Air Compressor on eBay!
UPDATE:
now there NO POWER to anything, with a new battery, do you remember what fuses you replaced, did you have to replace any relays?
There are two large primary power fuses in the trunk, behind the spare tire. Check those first.
See the wiring diagram here: http://jagrepair.com/images/AutoRepa.../jagxk2001.pdf
Particularly see pages 35 and 47. There are 2 mains fuses. If just the 250 amp fuse blew and not the 500 amp one, the ~5 volts you see could be due to leakage current through the starter circuit.
Is there a Link for a 2003 Jaguar S-Type Diagram?
#30
Please take a minute to update your forum signature with your car and model year.
Here is the S-type electrical diagram: http://jagrepair.com/images/Electric...al%20Guide.pdf
Charlene n John
09-28-2015 06:01 AM
