Accidental reverse polarity while trying to jump start a flat battery
Old 02-12-2012, 03:49 PM
Graham's Avatar
Default Update
UPDATE:
Thanks for all the help. I now have the car back on the road and seem to have got back to full function without any major damage. I could not manage to figure our which terminals of the diodes for multimeter test.
In case this happens to anyone else, my experience of reverse polarity jump start from a running similar car applied to a dead battery on an XJ8 was blown fuses in both kickboards and in the boot. None blown in the engine fuse box. Hopefully no damage.
Elfresh (05-19-2016)
Old 02-12-2012, 04:05 PM
Count_Damonee's Avatar
I like these,,, Because there might not ALWAYS be willing Jumper when you need them the most... And if you do reverse the polarity and screw their car up,,, Now you have a bigger problem... which neither of you can drive away from...
So check this out or something similar
1000 Peak Amp 12 Volt Battery Booster Pack Jump Starter Pac With Air Compressor on eBay!
Old 02-13-2012, 04:19 AM
Cadillac's Avatar
Good to hear everything is OK . Reverse jump start could really be result of expensive reapirs .
Old 05-19-2016, 10:12 AM
Elfresh's Avatar
Originally Posted by Graham
UPDATE:
i had a similar situation however instead of reverse polarity it was the positive lead touching a ground and it sparked.
now there NO POWER to anything, with a new battery, do you remember what fuses you replaced, did you have to replace any relays?
Old 05-19-2016, 10:25 AM
bladerunner919's Avatar
The OP hasn't been on the forum since November 2012, so I don't think he'll give you much guidance. If absolutely everything is dead I'd start with the main fuses next to the battery (to the left of the battery in the wheel well).
Old 05-19-2016, 10:44 AM
WhiteXKR's Avatar
Received 2,989 Likes on 2,125 Posts
There are two large primary power fuses in the trunk, behind the spare tire. Check those first.
Old 05-19-2016, 10:52 AM
Elfresh's Avatar
followed the leads to what I thought is the main fuse under a black cap with a multi-meter tested both sides it receives 12 volts and the fuse box receives 12V
however the Fuse boxes in the Engine bay and Passenger side fuse box only receive 5 volts
any ideas?
  #28
Old 05-19-2016, 11:39 AM
WhiteXKR's Avatar
See the wiring diagram here: http://jagrepair.com/images/AutoRepa.../jagxk2001.pdf
Particularly see pages 35 and 47. There are 2 mains fuses. If just the 250 amp fuse blew and not the 500 amp one, the ~5 volts you see could be due to leakage current through the starter circuit.
Old 05-19-2016, 11:48 AM
Elfresh's Avatar
i just noticed the forum i am in is incorrect, sorry its an S-Type 2003
Is there a Link for a 2003 Jaguar S-Type Diagram?
  #30
Old 05-19-2016, 12:18 PM
WhiteXKR's Avatar
Please take a minute to update your forum signature with your car and model year.
Here is the S-type electrical diagram: http://jagrepair.com/images/Electric...al%20Guide.pdf
JarodL
03-07-2024 01:39 AM
Charlene n John
09-28-2015 06:01 AM
tberg
09-07-2015 07:32 AM
Charlene n John
09-06-2015 11:03 AM
David Thompson
09-03-2015 07:48 PM
Quick Reply: Accidental reverse polarity while trying to jump start a flat battery
