Adaptive shocks?
Adaptive shocks?
Being relatively new to the forum, I apologize if this question has been answered a thousand times previously.
I have a 2005 XK8 with adaptive suspension. The right front shock is going bad, and I am planning to replace both sides while I am doing it.
I can find plenty of sources for the Bilstein shocks without adaptive suspension, but nothing for the adaptive system. Is this a dealer only part, or am I missing something?
Also, I am pretty sure I saw something on this forum a while back about putting non-adaptive shocks in instead of the adaptive ones, and just unhooking the wire at the top of the shocks. Has anybody done this, and how did you like the results?
Thanks, Rob
Thanks, Rob
I did it to my 2001 XKR. The shocks and mounts were bad when I bought it w/75k miles. Clunking and bouncing tires. When I went over bumps at speed I thought there were basket ***** under the fenders.
$400 instead of $2000+ seemed like a good idea for a car with now over 100k on it.
Cheaper shocks are MUCH better than broken ones. Be sure to replace the front upper shock mounting pads and maybe the sway bar bushings.
front shock | Partsgeek.com
The car handles fine and I have no regerts.
If just changing front shocks and disconnecting the module, would that create a problem for the rear shock? What about connecting a resistor to the front plugs and leaving the module plugged in?
The xk8 handling already leaves something to be desired without adding in more unpredictability, I think this would be best avoided.
IMHO you need to go one way or the other entirely. Don't mix CATS shocks on back with standard shocks on front. Don't try to trick the CATS system to use a mixed shock setup.
BTW, just disconnecting the CATS module defaults all four shocks to firm. Unplugging individual shocks at the shock will result in a suspension fault, which also will default all shocks to firm, but you'll have the suspension fault message and yellow light on your display.
Best Regards, Fred
RJ237 (10-02-2014)
Change them all, CATS is rubbish at the best of times and damn expensive
I just (@105k) replaced all of my CATS shocks with the standard ones, disconnecting the module in the trunk. Drives a lot better now, although I still am battling with some shakiness on bad roads. Replaced almost all suspension bushings and mounts as well. Still haven't done the upper wishbone mounts, because they look quite alright.
Any idea on what to do to battle some shakiness in a convertible? Subframe mounts? Stiffening of chassis? Roll cage?
Not a lot you can do about scuttle shake..... Jaguar was rubbish at convertible design, they nearly always produced a coupe and then chopped the roof off and added "siffening" to the chassis which never worked...... The reason being is producing coupes is cheaper than verts and once the money starts coming in they will do the conversion...
At least and lets hope with the F Type they did it around the correct way and simply added a roof to an already stiff shell........
A little unknown fact (going off on a slight tangent) the Toyota MR2 (MK2) was originally designed as a convertible but the Japanese decided to add the roof later and never produced the convertible but just a targa top...... This means you can chop the roof completely off and it makes no difference to the handling of the car
Chuck Schexnayder
33
10-24-2015 10:20 PM
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
