Adhesive Sealant Recommendations?
Hey Lads,
My aftermarket tail lights were originally held in place with some sort of adhesive sealant. I obviously do not know what was used originally but the stuff was very good at holding the assemblies in place.
I now have to replace mine after pulling them out for servicing and was wondering if anyone has a good recommendation for a seriously good product that will hold these things in place?
Commercially available stuff of course, I don't want to have to go ordering stuff in if I can avoid it.
The original stuff was grey in color and I need to stick with that. Can't risk using black in case there is some oozing
Was hoping to find some sort of flexible adhesive that I could cut out later if needed.
Bernie
Not sure if you can get it in the US, but Tiger Seal is brilliant stuff - sticks like s*** to a shovel, but can be cut out if eventually necessary.
Both black and white are available.
Otherwise, any polyurethane sealant should be OK
https://www.amazon.co.uk/Tiger-Polyu.../dp/B0039ZTYK0
