Adjust headlight
Guest
Posts: n/a
The driver's side headlight lowbeam(self leveling xenon) on my '03 XKR is too low. Is there any way to change the self leveler's "0" point. The lowbeam extends only about 2 carlengths in front of the vehicle and all is black beyond that. In my area one almost never gets to use the high beams because of traffic.
Received 2,191 Likes
no because your headlight is broken internally. (the plastic support posts that hold the inner assembly). want to ck it,,remove the plastic radiator cover that allows access to healights, now grab the high beam electrical connector and move it up and down, it shouldnt move, yours im sure will flop around. A cheap fix is to fashion with either tie straps, and rubber hose something to pull back and level the high beam connector to raise the light, however if totally broken this wont work. otherwise you need to buy a whole headlight assembly, but I do have a used Xtype assembly Im getting ready heat in the oven and pull apart and try some really good plastic epoxy I have to see the integrity of that repair.....good luck
ORIGINAL: 2purr4
I checked for movement. There is none. Were you refering to an X type or an XKR? I have an '03 XKR.
You adjust it with a 6mm. socket, there is one right behind the high beam and another one behind the low beam or HID, this one points east to west, you just stick a small ratchet and then and turn, easy! it's white.
captom (06-20-2011)
gunlocators
09-30-2015 08:05 AM
