Advice needed on XKR Radiator Replacement
Since I've been back in Texas, my XKR has been running a little hot. I've had to turn the air conditioner off several times when I was in traffic to keep it out of the red (yes, I have RealGauge). Because of this I thought I'd have the radiator flushed. However, when I took it into the shop they told me that the drain plug was stripped and were afraid to take it off to do the flush for fear of breaking the radiator. I've looked online and the radiators go for around $800. With labor we'd be looking at probably at least $1300, maybe more. Another option suggested by the shop is an upgraded Aluminum radiator for around $2000. The final option is to do nothing and hope for the best. As overheating is catastrophic for the engine, the last option is not very attractive to me. What do you guys suggest?
Mark
Mark
Be very, very careful ordering a radiator. Ordered mine and gave them my VIN and got the non-SC one, but for 2003.5 and greater and so I have one sitting in a closet ( my mechanic got one that day), company I ordered from would not send me another till they received mine, I could not wait.
Moral, ask lots of questions, including what size are the trans cooling ports and are they male/female. Because descriptions can be wrong on websites.
mjlaris (08-18-2014)
On my 2004 xkr the drain **** is hard to get at. Lots of stuff in the way and a messy way to drain the rad. The muffler shop I went to for a rad flush and thermostat change just opened the large input and output hoses up top of engine and used their flush apparatus to push 1st water and old coolant into large pails until clear then added rad cleaner, circulated that into every part of the rad system. The new 50/50 coolant was then added until it came thru. They then added the new stat. and circulated coolant to rid air. The s/c needed to be air bled too. Maybe the order of the steps are not bang on but just saying this an alternative to using the drain **** at bottom of rad.
Good question but yes, I checked and the fans are on with the AC.
Mark
I just replaced my radiator on a 2004 XKR. Partsgeek had one for $210.00. It worked perfectly. It was made by Nissens and had all the correct connections for the transmission lines (there was an adapter on the fittings). Also used an All Pro waterpump that I was pleased with, seemed the quality was as good as original at half the price.
Johnken (10-18-2015)
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 06:43 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 08:54 PM
