Advice on winter storage
and before someone suggests not storing her I will not drive my beautiful car in several inches of brine/slush and driving snow for several months
When storing my Miata/MX5 the accepted practice was this:
Do not put it up on jacks because it buggers up the suspension
Leave windows down a bit
Unlatch the convertible top to reduce tension
I will of course change the oil and use a battery tender and the car will be stored in an unheated garage.
Any other advice suggestions or comments ?
Actually, I have the opposite problem. My 1963 MK2 is not equipped with A/C, so it becomes too uncomfortable to drive during our summers. I do sympathize with those of you who are heading into the Northern Hemisphere winter. Whatever you're driving, please drive safely.
Stu
Stu
Received 2,266 Likes
Full tank of gas.
Don not run the engine .
I always max inflate the tires and fill the tank with stabilised fuel.
Don't understand your "don't run the engine" comment. I have always started stored vehicle two or three times during the winter and run them up to full operating temp for maybe 15 - 20 minutes...why not the Jag ?
it would be a good idea to close windows and roof tight to keep out rodents.
over one winter in an enclosed space, not much will go wrong.
make sure that you battery tender is a good one that cycles.
might want to give the leather a good coat of non-silicone conditioner
I've been storing mine for the last 7 years, in fact it has never seen the salty roads of England in the winter months. I agree with the fuel, tyres, battery conditioner (life support) and windows ajar, my car is a coupe, so no roof issues. Never started it, fear of condensation issues. There it sits for 4 or so months and has never caused me any issues.
if you are referring to the compressor seals, one or two seasons will not matter much in modern units. when a compressor leaks after storage it was probably close to the failure point anyway. replaced mine two years ago as the seals were beginning to leak after fifteen years near constant use. the OEM's are Denso and not very expensive.
Unless you live under water the condensation issue isn't all that problematic. I recommended firing it up once a month and drive it a bit. Keeps the juices flowing and exercises all the other components under it. There's seals and bushings and all sorts of other stuff that will stiffen and atrophy if it just sits for months on end. Just turn on and/or operate all the standard stuff. For a battery charger/tender I recommend getting a marine charger. The kind made by ProMariner are the best. The computer circuitry is smart enough to read your battery condition and it will do one of 3 things automatically. Full charge, trickle charger, and once a month it will run a full maintenance routine that makes your battery almost brand new. I've used them on boats, semi trucks, and cars, and every battery is fresh and ready to go.
Once mine is in the garage and the snow comes. It stays there until April ( if I'm lucky ) Sometimes the snow is several metres high between my garage and the driveway. Plus I would NEVER drive it once the city starts spreading road salt and spraying brine for ice control. As to condensation.......we have the worst conditions. Maritime climate with wet snow , freezing rain, then extreme cold , then warm ...rinse and repeat
Mikey (10-12-2017)
Looks like you have it covered, I've been storing mine over winter for 5 years using the above advice without issue. Except I use Sta-Bil in a full tank of gas. I'm not sure it does anything except keep Canadian Tire in business and makes me happy. See you in April, um, usually May, I like to wait for a good hard rain before coming out to play.
in the front of the rear wheel well there is a small plug which gives access to the rocker area. in the rear of the front wheel well at the rocker there is a Torx screw holding the wheel well lining. if you remove this screw, you have access to the forward section of the rocker area. underneath the car there is an open hole in the outer forward floor pans providing access to that wonderful space between the inner and outer floor pans that causes so much grief. i have not inspected it with an electrician's snake yet, but it and the other plugs in the vicinity might provide good access to this space without drilling.
best of luck with the car.
