Aftermarket Hood Liner
Anyone have experience with this type of hood liner? Looks interresting. Offers XK8 and XKR with louver cut outs.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
A year ago I didn't have an XKR hood on my car . Noticed the cutouts in my liner are already weeping fiberous entrails into my engine compartment, so a liner designed for an R would be a big help right now.
Here you go
Gonzo will print up anything you like at the end of the day, the Jaguar leaper is popular
Found a closer pic
All I will say is make sure you get the spray on glue he suggests, anything else will not handle the heat
Found a closer pic
Very nice, Tony. Guess I'll be getting an R liner with the Leaper decal . I'm assuming that after the liner is put on with the glue it becomes a permanent fixture.
Definatly. Trying to push that material up onto the hood with glue on everything could get messy, even disasterous.
Skid
I did mine last year, not that difficult. you'll have to remove the hood. I used a fiberglass roller to roll it out sprayed the 3M glue from top to bottom sprayed about a quarter of the hood and liner at a time. I masked all the painted area that wasn't covered by the liner. You'll have to keep working the areas down for a short time while the glue is setting up. I'll go out and photograph it tomorrow
Another Question
What is your reason for replacing the headliners? Are your current ones worn out? Are you getting some kind of better performance such as more noise absorption and/or heat dissipation? Is it a cosmetic improvement or some combination of the aforementioned items?
Thanks,
Scott
Thanks,
Scott
Those with X100 XKRs have a problem of the supercharger rubbing on the hood liner, this takes the paint off the supercharger and the hose clips rip the liner to pieces, they sag, they get dirty and cant be cleaned easy.
The replacement is glued directly to the hood, which gives more clearance, they can be cleaned and you can stick a nice graphic on them.......
Does the liner absorb the heat or repel it? Would removing the liner lower underbay temps, especially if someone installed an undersized SC pulley?
As quoted by XKR Racer
I wound up with some body shop dust on my hood liner after they cut the louver holes in my other hood, so I painted it with Dupli-Color heat resistant black spray paint before putting it on the XKR hood. Also had the louver holes trimmed up a bit...
Looks like this now...
Not bad for 10 years old, but then I don't have a supercharger.
