Aftermarket Stereo 99 XK8
I did reab d the other info but my wires are different colors. I did check with my tester and the brown/purple is 12v constant. I can't find the white 12v ignition. I have two that are 11.5v could be aerial and ignition.
I have:
Pink/white
green/black
black/yellow
Pink/black
Purple/pink
purple/red
grey/pink
grey/orange
purple/pink ( smaller gage)
green/black ( smaller gage)
blue/yellow
green/yellow
red/brown or yellow (smaller gage)
yellow/purple ( smaller gage)
yellow/white
red/blue
white/blue
red/purple
purple
large brown/purple 12v constant
Should I start cutting and check which cuts out ? do I need to keep positive and negative speaker separate ?
Thanks in advance.
I have:
Pink/white
green/black
black/yellow
Pink/black
Purple/pink
purple/red
grey/pink
grey/orange
blue/yellow
green/yellow
yellow/white
red/blue
white/blue
red/purple
purple
Thanks in advance.
zmann96 (04-29-2011)
I have:
Pink/white
green/black
black/yellow
Pink/black
Purple/pink
purple/red
grey/pink
grey/orange
blue/yellow
green/yellow
yellow/white
red/blue
white/blue
red/purple
purple
Thanks in advance.
I have:
Pink/white
green/black
black/yellow
Pink/black
Purple/pink
purple/red
grey/pink
grey/orange
blue/yellow
green/yellow
yellow/white
red/blue
white/blue
red/purple
purple
Thanks in advance.
You might need a magnifier and a bright light, but normally the pin numbers are embossed somewhere on the connector body. The pin numbers may be more accurate than the colors.
Pristine97XK8Convertible
04-28-2017 11:08 AM
