aftermarket wheels offset and center bore
Hi, 98 XK8 here. Looking at some aftermarket wheels, and need some advice. The set I am looking at is 20x10.5 rear and 20x9 front, with offset andcenter bore made to order. What is the least offset I can use to push the wheels out as wide as they can go without rubbing?
Also, I have always thought our center bore was 74.1mm. However, I am seeing all sorts of measurements on the forum: 73.9, 74.0, 73.1, etc. Does anyone know the actual hub bore?
Last edited by metalmarty; 06-12-2015 at 07:02 AM. Reason: I wrote "offset" instead of "hub bore"
Go to this site PCD jaguar xk8 wheels | PCD, Offset, Center Bore, mounting and tire size data . Measure what you have now, and add to the off set numbers, or go to a tire store, where the technicians know how to do this......Good luck.....Mike
metalmarty (06-12-2015)
Here's a good site for rim and tire comparisons though not vehicle specific.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
My 03 has 73.8 hubs as measured on the stock wheels.
What I was actually really looking for was someone who has figured out the maximum wheel width/offset combo that sticks out the farthest without rubbing or having to resort to fender rolling.
Thanks for the quick replies. I do know how to calculate offset, I was just in a rush typing the last post and wrote "offset" instead of "hub bore". So it looks like the commonly quoted 73.9mm is probably the most accurate measurement.
hunter34
19
09-14-2022 11:09 PM
