Air Con.
Air Con.
Very hot yesterday here in the UK 28c. Switched on the AC & Auto, blasted with cold air. Fiddled with controls, can't remember exactly what I did. Next minute only blowing cool air. More fiddling but she wouldn't blow cold even on min. setting.
Went out to the cat this morning with a print out of the diagnostic for the AC but came up with ' 0 no error codes '. Don't think it's low on gas as the problem occurred too suddenly.
Anyone have any idea what the course might be.
With thanks,
George. XK8 4.2 2003
With thanks,
Check to see if the A/C compressor clutch is engaged. If not the system may have fallen below the minimum static pressure required to operate the pressure switch. A look with a set of A/C gauges is in order.
There is an electrically operated water valve that controls the amount of engine coolant passing through the heater core. It can easily overcome the capabilities of the A/C system.
Couple places to start. The compressor clutch will tell you what to do next.
It was about 32C here yesterday.
Observe the A/C compressor pulley with the engine running and the Climate Control System off and you will see that the front center part is not rotating. Turn the system on and the center part should be rotating with the pulley. That is the compressor clutch.
If it is not, and after you have verified that all fuses are good, the first guess is that you are low on freon charge, second guess is that the pressure switch is not functioning correctly. Based on your question it would appear that professional assistance is going to be required at this point.
Just funnin' with ya'. I know bikes can be a blast. I rode for most of my life...hung around with a bunch of degenerates, when I lived in Chicago, and we all only knew on or off. All drove very fast Cafe bikes, but I was the chump on a modified 900 Kawasaki.
It was a time when I made my fastest run on any machine - 160 mph on a Ducati Desmo....for about 5 minutes, that is. Two of my old crowd are no longer around, both taken out on bikes in high speed accidents. Then, about ten years ago, I completely lost interest in bikes. Haven't been on one since then.
George
scooternva
20
09-27-2023 11:25 AM
scooternva
19
10-27-2015 02:14 PM
Poet
10-06-2015 09:40 PM
mel
09-20-2015 04:56 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
