Air cond. code 24
My AC isn't working. Here is the short. Hit a deer in June, got the damage fixed the ac was working prior but you could tell the clutch was starting to slip. Got it back from the body shop and the clutch had seized, replaced the compressor and drier and had it filled when it was in getting the motor mounts done. Today it is warm enough for it to come on and noda. Checked the codes it is showing a code 24 which is 24 Face vent demand potentiometer fault Potentiometer open / short circuit Harness / connector
fault Refer to PDU
The low side is showing 110 with the compressor off.
Thoughts out there. Not real good on ac myself.
fault Refer to PDU
TreVoRTasmin (11-24-2014)
Not yet, I had shoulder surgery 4 weeks ago so I'm in no shape to crawl under. As for the fuse. Haven't checked into that side yet as I need to figure out which one and where. Got your pm, will give you a shout tomorrow unless the number is good for evenings as well. Gotta get to a parent teacher conference in a few minutes.
Jim D (11-25-2014)
Guy-Pierre Boucher
09-16-2015 05:55 PM
OkieTim
09-08-2015 04:48 PM
