Air Conditioner runs warm
Old 07-30-2014, 01:56 PM
Bond2006's Avatar
Default Air Conditioner runs warm
Got a 2006 XK8 that blows warm air from A/C in park or standing traffic. Immediately the temp gauge starts to rise towards hot. No problem when driving. Fans work properly, new thermostat and water pump. Suggestions or experience?
Old 07-30-2014, 02:04 PM
brgjag's Avatar
did it do this before the new pump/tstat?
Old 07-30-2014, 06:30 PM
Stumpy's Avatar
Might just need refrigerant/gas topping up.
You can try running the Climate control internal diagnostics and see if that gives any answers.
See here for how to and codes:
Old 07-31-2014, 02:30 PM
oldmots's Avatar
More than likley, the fans are not working properly. This symptom is that of a failed cooling fan control module, I know, I just had the same symptoms.
Old 08-05-2014, 12:53 PM
Bond2006's Avatar
Not before the tstat but the water pump was the initial resolution; however, it apparently hasn't solved the issue.
cissdm
05-03-2016 06:02 AM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
tberg
09-07-2015 07:32 AM
Jjscruggs1
09-03-2015 07:46 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: Air Conditioner runs warm
