Air conditioning
Do you use the AC much in Norway?
Expect to lose approximately 5% charge each year. The only way I'm aware of to check for leaks is with a tracer dye.
When I have my AC recharged, the machine they use does the following:
1. remove residual R134/PAG oil
2. pressure test
3. re-charge with correct weight R134/PAG oil
In the one instance I had of a car failing the pressure test (2), they used a dye to find the source so i didn't pay for the re-charge (3) until it was fixed.
2. pressure test
mine stopped working, I just went to the local auto place and threw in a can and it has been working fine now for 4 or so months. I have done this with many of my cars through the years and have never had one that was shot and leaked out in a day or so. I always got a year or two out of them then had to top them off again.
I have my 74 Olds 88 convert, didn't come with AC so the tops goes down today on the way home.
oyster (07-16-2015)
This is what i used to find my leak when i rebuilt my A/C system
Link Electronic Freon and Halogen Leak Detector
xjrjag
09-27-2015 01:53 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
