Air intake gaskets
Are you referring to the large rubber gasket on the throttle body that the hose from the MAF sensor connects to? If so, check the hose itself. I just replaced mine and it took some plastic clean-up work on that end to get it to fit well.
Take the rubber seal off, install it on the hose first, then attach the assembly to the throttle body. That worked much better for me.
