Airbag System Flash Codes - can AutoEnginuity clear them?
Old 04-21-2012, 01:41 PM
GGG is offline
Received 16,850 Likes on 12,185 Posts
Default Airbag System Flash Codes - can AutoEnginuity clear them?
Does AutoEnginuity with the Jaguar Enhancement Package allow SRS (Supplemental Restraint System) 'Bxxxx' codes to be read and cleared?
I've got the older version of AutoEnginuity which doesn't support the Jaguar extension so it means buying the whole package. No point in doing this if it won't let me clear the codes.
The airbag warning Light is giving Flash Code 17 (1 flash + 7 flashes repeated three times before a permanent airbag warning light is displayed):
JAGUAR XK Supplemental Restraint System - 501-55 SRS Flash Codes.pdf
After checking the possible causes detailed in the TSB, the codes still have to be cleared. Rectifying the fault doesn't put the warning light out.
Old 04-21-2012, 05:37 PM
thefixer's Avatar
Are you certain? On my '03 XKR I had a bad connector to the bag in the drivers seat. Fixing the problem cleared the flashing...
-Steve
Old 04-21-2012, 06:02 PM
wcnesta's Avatar
My 03 XKR had a 22 air bag error code and after I cleaned all the connectors in the drivers seat it took care of the air bag error lite.
Bill
Old 04-21-2012, 06:09 PM
GGG is offline
-Steve
You can never be certain with Jaguar electronics.
With the seat track fault, did you get a constantly illuminated airbag warning immediately after starting the vehicle or a series of flashes first?
Old 04-21-2012, 06:13 PM
GGG is offline
Bill
Bill,
A sanity check that I'm interpreting flash codes correctly:
1 flash : pause : 7 flashes
This is followed by a long pause and the same sequence runs twice more. I've assumed this means Code 17. Is that right?
JarodL
03-07-2024 01:39 AM
Forcedair1
05-14-2023 03:28 PM
Jpav27
07-31-2022 06:43 AM
Bcrary3
09-12-2021 05:41 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Airbag System Flash Codes - can AutoEnginuity clear them?
