Alignment Printout
Hi Guys,
I had my car aligned today, not a jag dealer, would have had to drive 8 hours round trip to the nearest dealer. I did ask around for the best and drove 3.5 hours. ( I know, I'm in the boonies). Insteads of scanning it in to my laptop I'll set it up.
Front
Left Right
Camber -1.1 -1.1
cross camber 0.0
Caster 5.9 deg 6.6 deg
cross caster -.07
toe 0.13 deg 0.12 deg
Total toe .25 deg
Rear
camber -1.1 -1.1
Cross camber .0
toe .11 deg .14 deg
Total toe .25 deg
Thrust angle -.01 deg
He told me the rear camber was on the fence but didn't think it would wera tires.He did say the from toe was out b ut didn't give me the print out. I had thought that it was the springs for the camber so to try it before I purchased new springs I poped in two spring spacers on each side of the front and it did pick up the front an 1" on both sides. So I will be buying new springs. I may just replace all the bushings I haven't already replaced and be done with it.
Any suggestions? thanks guys
Front
Left Right
Camber -1.1 -1.1
cross camber 0.0
cross caster -.07
Total toe .25 deg
Rear
camber -1.1 -1.1
Cross camber .0
toe .11 deg .14 deg
Total toe .25 deg
Received 2,190 Likes
