Alloy Backed Timing Chain Guide Rails
Old 02-29-2016, 03:40 AM
Jagman28's Avatar
Default Alloy Backed Timing Chain Guide Rails
Dear Sirs,
Is it possible to install later generation type alloy back timing chain guides in early model v8 ? Mine was done a few years ago and they changed the tensioners with alloy type but the guide rails are stil plastic ones.
Regards
Old 02-29-2016, 05:47 AM
Addicted2boost's Avatar
Received 1,031 Likes on 811 Posts
I do know what you mean but, all the chains ride on some sort of plastic. You can't have metal chains riding on raw aluminum even with oil between them. What is your primary concern with what has already been replaced?
Old 02-29-2016, 08:30 AM
batroute's Avatar
The later type alloy backed guides will fit the earlier engines - my understanding is that they are more robust. Presumably that's why Jaguar changed to the later design.
Old 02-29-2016, 08:40 AM
Paul Pavlik's Avatar
The early production Primary Chain guides and tensioners are less prone to catastrophic failure than the Secondary Chain Tensioners but require removal of the Front Cover (a quite involved job).
baldeagle15
75
08-02-2017 10:29 AM
myshao
03-07-2016 01:39 PM
amcastro1
03-02-2016 07:27 AM
Raslok
02-26-2016 02:55 AM
slauson slim
02-22-2016 10:26 PM
Quick Reply: Alloy Backed Timing Chain Guide Rails
