Alpine Sound System
Old 10-03-2015, 09:44 AM
mikecsboats's Avatar
Question Alpine Sound System
The Apine sound system fitted to my 2002 XKR has gone silent. The controls work and the display display shows changed stations and wavebands, and all other functions appear to work, with the one exception that it is not possible to access the CD changer.
And there is no sound, not on the radio, or satnav.
This happened last year,and then, after a couple of weeks, the sound came on again, and worked normally until last week. Now it has happened again. I have checked all the fuses without finding any problems.
Anyone got any ideas?
Regards,
Michael Campbell-Smith
Old 10-03-2015, 10:01 AM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
It sounds like a problem with the premium sound power amp.
Have you checked fuse #18 in the boot?....This is for the power amp.
If the fuse is OK, check the power amp (over the CD changer). Re-seat the connectors and make sure no water is dripping on it. If all else fails, you usually can find used ones on eBay.
mikecsboats (10-05-2015)
Old 10-03-2015, 01:56 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
Originally Posted by mikecsboats
The Apine sound system fitted to my 2002 XKR has gone silent. .............
Michael,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post tech questions about your model.
Old 10-04-2015, 10:22 AM
Thanks Graham. I wasn't sure as I thought that the Alpine system might have ben fitted to other Jaguar models.
Mike
St.Regis
04-06-2021 12:34 AM
2001 White XJ8
02-25-2021 05:02 PM
mbergen
10-23-2019 10:26 PM
Dicque
09-19-2015 12:53 PM
Burdedw
09-12-2015 10:39 AM
Quick Reply: Alpine Sound System
