Alright Dudes, possible XK8 purchase Part Deux, I need part pricing ball parkish.
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
First the good:
![Icon Drool](https://www.jaguarforums.com/forum/images/smilies/icon_drool.gif)
Tranny shifted through five fine, engine fired right up and no uneven idle or pauses.
power top works up and down be it a bit slow. What does it take to Flush?
Now the bad:
![Icon Toliet](https://www.jaguarforums.com/forum/images/smilies/icon_toliet.gif)
I noticed the front end had some wobble to the steering wheel. May be wheels off balance, maybe suspension bushings. Tracked straight but bit bumpy.
Headrests and steering wheel adjustments are shot or not moving as supposed. Costs and how big a fuhk is this to fix?
Chrome 18s showing their age. Any way to de-chrome and powder coat?
And finally lack of maintence records. She has owned for the last few years and it appears only oil changes have been done. I take this to believe I need to Change oil, power steering, brake fluid, diff fluid, tranny fluid, and the coolant. Maybe the plugs? What are costs on supplies for this venture?
My thoughts to conclude:
I liked the car, it drove beastly, looked fuhking hot, and the cool factor is through the roof. I am thinking of taking it to a local Jag shop in town having a pre-purchase done on the car and then getting the car for a song. If she wont budge then I will have to walk.
I know this was a bit of reading but you dudes rock giant donkey ***** for all of your help.
![Icon Snowball](https://www.jaguarforums.com/forum/images/smilies/icon_snowball.gif)
Moltenburn
So, it's a 2001, and you know the tensioners are good based on what? Sounds like some front end work is due for sure.
I just read your first post. You need to have a GOOD Jag tech look at this car beofre you do anything else. Even $10,500 is a bust if you have to put another $4-5-6-7000 into it.
Moltenburn (05-09-2012)
The car is a 2002 with a build date of Sept 2001. I was informed the tensioners from this date on were the metal variety.
If I decide to bite the next stop will be a Jag tech in town. Anyone with any pricing info on supplies for the fluid swaps, would be appreciated.
From the forum sticky:
Originally Posted by test point : The engine serial number encodes the date the engine came off the engine assembly line. The conversion to metal tensioners occurred on August 13, 2001, thus a serial number of 010813xxxx (YYMMDDHHMM). There is no direct correlation between the engine serial number (date of engine assembly) and the VIN although a dealer can provide the engine number from the VIN.
Consider a chrome wheel exchange program on ebay:
jaguar wheel exchange | eBay
I did not see any reference to miles. That is the price determination factor.
By '02 Jaguar had most of the chronic issues fixed.
There is a airbag fault code list around, probably in the FAQ sticky, but I seem to remember that most focus on seat belt wiring issues.
Headrest is easy and cheap. Tilt steering wheel is not difficult, reach is more difficult requiring a steering column replacement at a dealer. Repairable DIY but a PITA.
If you are willing to DIY these are wonderful cars to own. If you must take them to a dealer or even an indy they can be a real money pit. These cars are best owned by hobby mechanics.
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
