Alt power steering fluid
Just finished replacing front lines to the power latch and topping off fluid in the pump. Also, I just finished replacing the power steering reservoir and the power steering fluid cooler line. I used Pentosin CHS at the pump for the top. So would said fluid play nice in the PAS system and well with any remaining fluid?
The pentosin is a hydraulic fluid for high pressure systems. ATF properties are very different and you should definitely not use the Pentosin.
You can use on of the many synthetic ATF fluids that are compatible. Just check the label to be sure it is a Dexron III substitute. Dexron III is getting hard to find as the newer synthetics are superior.
