Alternator replacement
I'm about to replace the Alternator on my 99 XKR using the sticky procedure below.
http://www.jagrepair.com/AlternatorRepl1999xk8.htm
Have read lots of conflicting posts about not removing half the things suggested or that you should tackle thd job from underneath etc and as the posts I've read are a few years old I was wondering if there is a more agreed upon way to replace the Alternator or if anyone has a new guide I could follow?
2000 XK8 Experience
JagRepair.com - Jaguar Repair Information Resource
Plenty of room to just lift it out.
No special tool required
The oil filter is just the usual spin on filter. Usually you can just remove by hand. Any standard oil filter wrench will work if it is in really tight.
Phil m (05-24-2024)
Phil m (05-28-2024)
Ehh
For me I worked from both under and above it sucks there's no videos on this but you can remove the intake box, unplug the vvt and then go from under and disconnect the wiring to the alternator, and then you just gotta work the alternator out from the top. May take a few tries but it will com out. then reverse the process.
When I put a new alternator back in I had issues with fitment because it was a bot thicker so I had to sand and hammer it in. (tight fit but I know it for sure wont move!)
Ehh
The following 2 users liked this post by ocwolfy:
markmywords (05-28-2024),
Phil m (05-28-2024)
The bracket is noticeably larger than the alternator case thickness, necessitating the need for the stupid bushing. The process after alternator removal is to push that bushing all the way back using a bolt and a nut. Bolt goes in from the rear, nut from the front, crank until the bushing is back all the way. Then the alternator fits loosely until you torque down the bolt, moving the bushing inward to compensate for the variation in alternator case thickness.
Richard
The following 5 users liked this post by RichardS:
Don B (06-07-2024),
ocwolfy (05-28-2024),
Phil m (05-28-2024),
toaster (05-31-2024)
The tight sliding bushing is the standard fitment method with most alternators in my experience. I usually just tap the bushing back in with a couple of soft hammer blows before I fit the alternator which make it a loose, easy fit. It only takes a couple of seconds.
Richard
Richard
Hi All
Regarding alternators, I have recently finally changed my alternator on my 2000 XK8..It is really simple..
Having done it 3 times now....My supplier sent the wrong one.6 band multi V not 7!
The 3 rd time we did in 50 minutes!
Disconnect battery earth!
ABOVE
Remove air filter
Remove filterbox
Remove filterbox support bracket
Remove drive belt off the alternator pully only..tensioner is easily accessable, have some one hold the tensioner to aid removal
Underneath
Remove the cooling duct
Undo the13mm bolt through the alternator..Very very diffcult first time, as it will be stuck solid!
We used a bit of local heat to warm the alternator lug to help break the Steel/Aluminuim bond
Unplug the cable connector and the main charging cable
Above
Remove the top bolt
LIft up alternator up through the space
We found no need to remove hoses, Oil filter etc.
Fitting is the reverse!
Good luck
ABOVE
Remove air filter
Remove filterbox
Underneath
Above
Remove the top bolt
Good luck
I finally started the job today due to life commitments.
I've removed the bolt from underneath the car, the nut & bolt from above, removed the oil filter for access but I just can't get the Alternator to slide back to the rear of the car a little do I can lift it out.
Any suggestions greatly appreciated?
Ok,
Well we on our first time, aside from dunking it in WD40, and the heat to aid bolt removal, eased it out with a prize bar(but be careful not to break anything off!).. from above if I remember correctly, between the Alternator and the bracket..Heat may have freed the bush a wee bit
It just needs gentle nudge, and off it slipped... The annoying floating bush seemed to slide in when sideways pressure applied!
As you have removed the Oil filter, you maybe able prize from below...I assume it is pivoting on the bush as well which will help loosen things..
I hope this helps..Good luck!
My next joyful job is to remove the inlet manifold to change the Valley heat pipes! Arrgh.....
markmywords (06-06-2024)
I worked from the bottom. Removed the bolt, Got a pry bar and rocked the alt back and forth a few times to loosen, the gently pried between the block and alt. it budged. Continual pressure and rocking back and forth got it to slide out. I didn't have to remove my oil filter. The alt came up from the top (after removal of the air cleaner and mounting bracket), after jiggering it around into the correct position.
The following 3 users liked this post by Y2KJag:
The saga continues, I've freed the Alternator now but I just can seem to pull the Alternator through the gap.
Below is the gap with the Alternator below.
Below is the same gap with the Alternator in the middle.
There is a lug which is stopping the damn thing from being freed, any advise would be appreciated?
Received 2,422 Likes
The following 4 users liked this post by michaelh:
I've removed the Alternator now thanks to Michael's advice.
When attaching the replacement I read somewhere that the lug circled in red below can be retracted is that correct?
I've used WD40, plyers, tapped it with a hammer but it won't move.
The pic it taken from below the car and I have compared the old and replacement alternators to comfirm they are identical.
