2004 XK8 Convertible. I am trying to get the dash lights in the centre stack working, no lights at all so I figure it isrelated to the dimmer control module or dimmer Switch. First thing thought is to check the fuse. Aparrently it is fuse 13 on the passenger fuse box. Trying to figure out which one is fuse 13. I wonder if maybe I am missing covers that might show the numbers. Neither side has a cover.
No, look with a flashlight at the grey plastic to the left of the left column of fuses or to the right of the right column of fuses. The numbers are embossed in the plastic next to each fuse.
