Annoying Dash Squeak
I have this annoying unidentified squeak in the interior that occurs while driving at any speed as long as the car is moving over anything less than smooth asphalt. It sounds like a creaky door hinge or like a cricket that loves ***** cats.
I've only had it for about a week and it is driving me to the loony bin.
Here's a video where it can be heard.
LondonGirlDXB (07-18-2021)
Geez that would drive me nuts!! I hate any clicks or rattles in the car and these are always tough to find. I've had cars where rattles inside that sounded like they were coming from the front were actually from the rear, and vice versa.
Let us know if you figure this one out. Could it be the seat or the steering wheel or maybe even the glovebox?
Doug
Doug
I had those replaced last summer. I am positive the sound is coming from the interior. When I rolled down my windows, there was no difference in the sound.
I don't know if it could be the seat, the steering wheel or the glove box. It sounds like its coming from inside the dash.
giandanielxk8 (01-31-2016)
I agree with Addicted2Boost that this is a suspension squeak. When this exact same noise happened to my XKR100, my wife and I were on our way to a club function. We both thought it was a dash noise. After about thirty minutes of that noise ,you are ready to use Uber. Anyway,to find out one way or the other, just bounce the front end on each side and see if you hear anything. I replaced one side shock mount and the noise went away. The other side started squeaking within three weeks.
I bounced all four corners of the car with as much strength as I could muster and no squeaks were produced. I did have nearly all of the front suspension rebuilt last year so I'm pretty sure that that's not the source of the squeak.
I did as Paul suggested and checked the dash screws. The center screw was a quarter of a turn loose. I tightened it up but I haven't gone for a ride to check if that stops the noise.
Jag#4 I'll check that as well.
I have the same noise but mines more intense. I'm thinking it might be the upper control arm bushings because I haven't replace those as I have with the other bushings. It really is annoying going over the slightest bump..
