Annoying Dash Squeak
I too have some strange noise sometime in my convertible.
It took me long time but I found them:
- inside the header rail panel (not sure of the name here), the top trim part of the windshield. I had a broken plastic clip
- central mirror, same here, one clip was broken
You could also check: seat rails, door panels (inside), seat belt clip
And it can also be something in the rear, one of the worst to find in my coupe was... the 3rd brake light! Broken by UV, got loose etc
I finally figured out the source of my squeak. The drivers side upper shock mount failed prematurely. The donut bushing seems to be in good shape but the strut is out of place. Perhaps the shims on the plate broke off.
I'm going to contact SNG Barratt about it, the part is less than two years old. The other part is still in good shape.
giandanielxk8 (02-05-2016)
Dash noise
giandanielxk8, When you pushed down in the fender did you hear the noise? I finally figured out the source of my squeak. The drivers side upper shock mount failed prematurely. The donut bushing seems to be in good shape but the strut is out of place. Perhaps the shims on the plate broke off.
The squeak is gone!
I'm happy and dancing, the squeak is gone!
giandanielxk8 gave a great tip when he said it ended up being a bushing. I never would have believed that. I would have bet it was from the dash. But after reading about the bushing idea, I woke up the next day and sprayed WD 40 on the top of the struts and turned the front wheels both ways and sprayed every bushing I saw. That was it and the squeak is gone! THANK YOU!
#28
#30
#31
I have this annoying unidentified squeak in the interior that occurs while driving at any speed as long as the car is moving over anything less than smooth asphalt. It sounds like a creaky door hinge or like a cricket that loves ***** cats.
I've only had it for about a week and it is driving me to the loony bin.
Here's a video where it can be heard.
