Annoying error codes ...anyone solved theirs?
Hi guys,
I know there are some of you have lived with some annoying codes that's never go away...I got some too ...I wonder if you guys have ever solved any of these? Thank's fellas
P0110 intake air temperature sensor circuit
c1300
p2200
u1041 SCP Speed signal - invalid or missing data
B1595 ignition switch - illegal input
u2012 communication bus error
u1135 ignition status not obtained
b2323 local mirror drive, left/right out of range low
b2327 local mirror drive, up/down out of range low
b24bd diagnostic trouble code invalid
p0562 system voltage low
U1262 scp (J1850) communication bus fault
c1300
p2200
I would be looking at the battery and connections.
Gus
www.jagrepair.com
Gus
www.jagrepair.com
Hi guys,
c1300
p2200
c1300
p2200
I tried to clear it...but my ingenuity scanner keep telling me ...failed to clear dtc.
My first suspect is also the battery...is there any way we know that the battery is at it's end of its life?
I guess I could ignore it but I don't want to be ignoring the important ones if I am ignoring that dang "SC system fault"
Bigvettefreak
10-24-2015 08:47 PM
