another amber alert
That sounds familiar. I pulled my records and I had this happen to my Coupe in 2004. Hear is a list of what they used to fix the problem.
1EA LNC-3380AA HARNESS
2EA. JLM-020212 O-RING
1EA. JLM-020213 CLIP-RETAINING
1EA. JLM-020204 GASKET SUMP
1EA. JLM-020216 FILTER SUMP
1EA. JLM-020217 O-RING
2EA. JLM-020237 OIL-AUTO TRANS
This is how they wrote up the ticket:
Customer states high gearbox temperature light came on message center. Diagnosis procedure. Use WDS to check for codes. Found code P0711. Root cause. Intermittent open in trans fluid temp sensor. Failed/defective part. Trans internal harness repair procedure. Replace harness, clear codes and test drive 7 miles. OK. Technician concern code, 28 (2.8 hours).
Sorry I cannot give the price because this was covered under extended service warranty. I hope this answers your question. That is if you pulled a P0711 code.
Wow, that felt good to give an intelligent response for once.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
iron jaw (07-17-2011)
Wow, that felt good to give an intelligent response for once.![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Received 6,320 Likes
I changed a bunch of those 5HP24 internal harnesses for the temp sensor fault. Get a new harness and that should fix your problem unless you know the fluid was actually overheated from a blocked cooler pipe or stressing the gearbox by RACING or climbing a mountain towing a trailer.
bob gauff
bob gauff
iron jaw (07-18-2011)
iron jaw (07-19-2011)
Johnken
09-22-2015 03:53 PM
Johnken
09-15-2015 05:46 PM
