Another Real Gauge save
I just replaced mine with an AC Delco water pump, mainly because that's what someone on here recommended. No problem with it, but I'm pretty certain the casing is two pieces. I'm also waiting for my new aluminum thermostat tower assembly - whatever it's called. Mine is weeping coolant and I'll be glad to stop that aroma from wafting around my cabin.
Well, I hope these bozos aren't lying to me -
https://www.ebay.com/itm/For-Jaguar-...53.m2749.l2649
I hope that link works. It says it will fit a 2006 XK8.
The spike in the temp reading could be as simple as low coolant - if you have an air pocket near the thermostat it could cause a temporary reading. Never had that happen on my car but past vehicles, yes.
As for the aluminum "upgraded" thermostat housing, I've only heard negatives about that. While it seemed like a good idea in theory, mechanics have said the parts never lined up correctly and when heated they leaked. YMMV.
