Another seat Module issue
The passenger side seat will not move up or back. I did the swap and only heard a clicking sound pressing it both ways(before only one way).Placed the "bad" passenger module in drivers seat and only reclined. that's more than it would do in the passengers seat.....
Checked the fuses as well. Any ideas as to what it could be?
Since you have power to the seats, you are now looking at the switch pack, the module, and the motors, and associated drives. Any one item within these mechanisms may be the problem. There are a number of threads and related TSB's pertaining to the seat modules, including everything from the seat rubbing against the wires, module cases, etc.
Do a thread search "Seat Module" and a listing of diagnostic procedures and TSB's will be included.
My thoughts are that if it were the switch pack or Motor on the passenger side,it would have worked when I tried it on the driver's side. But it only reclined.
What are the chances of all 3 items going out on the same seat?
Possibly a switch pack and broken tracking in the module,hence it only reclines when placed on the Driver's side.
If only there was a way to incline it just a little bit to make my wife happy!
The seat back recline relay closure traces (which drive the motors) are at the edge of the seat module printed circuit board and are the ones most susceptable to the case abrasion and environment that makes them crack or corrode and dissolve.
I would be inclined (no pun intended
) to closely inspect both of your module circuit boards in this area with a magnifier and an ohmeter. The cases just snap open. It is possible that even your 'good' module is not so good.
It would also be a good idea to check your under seat wiring for chafed insulation.
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
I did pop it open and clean the board. I did notice some "tracking" arround the outter edges,but dismissed it because the good module did not work. Looks like it points to the wiring under the seat and possible break in outter tracks which control the incline input from switch.
All evidence points to wiring and module given evrything else. Would you agree?
Thanks for your help.
David
David
David
David
dad2twins (10-28-2011)
dad2twins (10-29-2011)
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
