Another successful headrest fix
Big thanks to Seismicguy for his written how-to and pictures and the tips from the other members.
Both of my headrests are now working properly (although it took 4 hours to finish both, including one trip to the store for a Torx set containing the correct size :-))
Thank you all!
Thank you all!
Headrest fix
I've repaired similar items and it may help to scuff the cable sheeth with a bit of coarse sandpaper then apply a very thin coat of Goop underneath the heat-shrink. Don't put it near the inside join as you don't want any on the cable. Heat gun is the best tool for the heat-shrink. If you're using a commercial grade gun careful of the heat on the plastics.
Thanks--I will try the scuff and goop approach this time. Curiously, the headrest started working again so I think what is happening is that bumps and motions caused by driving must end up moving the cable a bit causing the opening and closing up of the splice. I think when I re-do the shrink tube I will also wire tie the cable to something so that it does not flop around so much.
Doug
Doug
Opened up the seat again today to tighten up the splice. I used a soldering iron to further shrink the heat shrink but I suspect the splice will again loosen up over time. I think the stress on the inner speedometer-type cable just tends to want to translate to the sheathing, thus eventually forcing the splice open.
That being said, does anyone know if Jaguar ever came out with a cable/sheath assembly that is the correct length as a replacement for the original or is the dealer repair still involve the cut-splice method? If there actually is a proper replacement assembly, I would rather just get that and not have to worry again about the splice separating.
Doug
Doug
Get the heat shrink tubing from a marine store like west Marine. They have the kind with glue inside, to keep water out in a marine environment. The glue will help hold it on and the tubing is thicker as well. I used this on mine and doubled it up to make the splice have less flex, never has pulled apart. There is also the chance you cut it too short and its bottoming out when fully installed, this would also cause your problem.
Doug
The heatshrink I bought was from Radio Shack and rather thin which allows for flexing at the splice. I removed the exact amount from the sheathing and verified the problem to be flexing which allows the splice to open a bit. In the meantime, it is fine but I will check for the heavier heat shrink if I get the chance.
Doug
Doug
Received 2,192 Likes
^^^robert that is your problem, also i have said in other posts. Use 2 pieces of heat shrink, 1 shrunk, then slip another over and shrink. Then i use electrical tape to wrap and go down and include the original cable sheath. This keeps it from serating. Or use the heat shrink with glue as mentioned earlier in thread
Did the headrest procedure today on my 2001 XKR. Used the glue (epoxy) and single heatshrink plus electrical tape approach. Did the cut about 2 inches from the motor.
The previous owner had disconnected the headrest motors ...no clue as to why. Anyway made the mod and plugged it back together...It all works great!!
Thanks to everyone for their tips.
Wolfy
05-28-2024 08:06 AM
aholbro1
08-05-2021 05:02 AM
