Anothere question about radios/stereos
I have literally spent hours sifting through threads and comments about replacing the radio/stereo head units and ,sadly, am still a bit confused.
1/Forget about steering wheel controls , they are not important to me.
2/I do not have a navigation system or cd changer in the trunk; just a radio/cassette.
3/Wiring does not scare me. Even though there may be a harness adaptor available in the UK , Autoleads PC2-55-4 Car Audio Harness Adaptor Lead, and I have a very reliable way of getting Amazon UK stuf.
Is the problem with fitting a new head a physical issue ? Basically that there is no "dash kit" to make the new head fit in the hole where the old one was ?
My apologies if I'm just being thick and this has been explained before
Is there a reason to replace the radio? Radios typically can be repaired, or procured cheaply on eBay. This is for the stock /factory look, but the low tech unit. FWIW, I believe US (North American?) head units have no lock code after being powered off.
The folks that have done this conversion seem to have mentioned the trim kit of the XJ series to be workable. I do not have the specifics, but I would assume the older X308 series.
Best of luck, keep us posted.
I want to replace it because it's a plain old radio/cassette unit.........I have not owned a cassette tape for about 30 years or anything that could even play a cassette tape for over 20 years. I DON'T want a cd changer in the truck.
I would like to have Bluetooth connectivity so that I could stream from my phone or answer calls and USB would be nice as well....so that implies a new head unit.
All I am trying to find out is why it seem to be such a problem to install one ? Is it a physical limitation/ problem ? As I stated before I don't care about steering wheel controls and wiring a head units does not bother me either.
For music, it is a bit harder. Folks have hacked the tape player with an external jack. Of course there are cassette "tapes" with Bluetooth. There is also the option of hijacking the sound wires of the CD player (which you do not have, I believe), and last the option of using a WIRED FM adapter. That FM adapter takes in the sound from the Bluetooth box, and sends it to a specific pretend radio station straight to the antenna input of the radio, over a WIRE. This is not the old wireless FM transmitter that caught a lot of interference.
I have this FM wired transmitter, so I am familiar with the installation.
The net result is invisible. The radio remains consistent with the original design. The trim is "perfect" because it is unchanged. The steering controls work, which is nice for the volume. The net result is OK sound and a workable solution, but certainly not something to be ecstatic about.
Just my experience. Hope this helps.
Johnken (09-19-2017)
The 2004 Model year XK8 has a strange offset. The space is not big enough for a 2DIN unit, and with the stock backplate a 1DIN is a bit off.
The solution is to get the 1DIN plate from a 1997 XK8 (~$35) and then you can install any 1DIN you would like. I would avoid flip out units as the gear selector will interfere with its operation.
You can search posts (look at the FAQ or search me and stereo) and find the exact part numbers to make a 1DIN install pretty straightforward.
-dsd
-dsd
Barry,
I just replaced my 97 radio with the kit for the 97. Not sure what your dash looks like but I thought your heating and lighting controls were different then a 97 so buying that jag facia plate and the din adaptor may not work for ya. I used an Axxis steering wheel controller for mine that was pretty easy to set up and works pretty good. A little delay but at least the volume and the select works so I can be lazy. Sound from my $100 clarion radio is as good if not better then the stock unit plus now I have a 16 gig sd card with 3000 songs on it. It does have bluetooth as well but I'm not that tech savy (well really I don't talk to people).
Apparently this kit will do the job.
If you scroll down to the vehicle listing, page 3 I think, you can see it states it will fit your 2004 model XK8.
Bit on the pricy side in my mind, but it looks like it will solve your problem of fitting a new single din head unit with bluetooth connectivity if you don't want to use the aux plug that is supposed to be in there already and fit extra stuff.
Might be worth an email to the company just to check.
BACK SINGLE DIN JAGUAR XK8 CONVERTIBLE 1996 to 2005 FULL FASCIA FITTING KIT | eBay
On my Motorola bluetooth adaptor, there are separate stereo outputs for music streaming along with the mono connection for the phone.
On mine it is wired up as fmertz has described, to the connector under the armrest. There are a number of options to get the stereo output from a bluetooth adaptor to your existing head unit. I preferred to keep everything looking original, but if you want to change the head unit that is probably going to be your easiest option.
