Antenna lube
Antenna lube
Washed the car for the first time today and found "black stuff" coming off the antenna. Having read many postings over the past month, I do know that a lack of lubrication on the antenna leads to it not working so well. Therefore, what is the lube that should be used on this and what, every time I wash it?
+1 on avoiding dust accumulation.
I just wipe mine down (every few months or so) with a rag wet with paint thinner / turpentine. When I bought the car, the antenna did this noticeable chatter-thing for the last 6 to 8 inches of retraction. This has significantly improved since then. It still does a little chattering, but seems to be continually improving.
Silicone Spray Caution:
After wiping the antenna down with spirits, use a soft cloth but spray your CLOTH with the silicone spray and rub the antenna...DO NOT DIRECTLY SPRAY THE ANTENNA SHAFT!
Silicone has a tendency to 'gum-up' over time if too much is used, and could make your problem even worse than when you first started.
