Antenna plug on radio
Can someone describe the physical location where the antenna plugs into the back of the radio ? I apparently can't use the antenna connection in the trunk for my Bluetooth device so I need to plug it into the back of the radio. I am aware of the process fro removing the radio but I'm hoping to just be able to remove the glove box of pull back the carpets a bit and maybe reach the antenna plug. This of course depends on knowing exactly where it is......lower left ...middle of the back...upper right etc.
Yup managed to get it
Now I need to find a switched power source , but that should not be too hard in the huge bunch of wires behind the glove box. The auxiliary plug in the glove box is always powered. There is a third terminal in the connector for it but it does not seem to carry any power at all
Since you have the same year as mine you should be able to do something like this.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x2000/wp_20170114_001_cc775b9dfa74e95f5879b8a5f1f1be1ae29ad541.jpg)
coudamau
01-03-2014 12:04 PM
