Antenna travel
Old 12-20-2012, 07:22 AM
Rramshur's Avatar
Default Antenna travel
How is the antenna up/down travel adjusted?
I just had a local (non-Jag) shop install a replacement antenna it won't fully extend/retract.
Any clues?
Thanks.
Bob
Old 12-20-2012, 07:30 AM
Gus's Avatar
Gus
Gus is offline
Received 2,212 Likes on 1,702 Posts
Spray with a little WD40 and operate it several times then wipe off the residue and do it again and see if it improves the operation. When you are done remove the residue of the WD40 from the antenna mast.
Rramshur (12-20-2012)
Old 12-20-2012, 11:14 AM
Jon89's Avatar
Received 4,357 Likes on 2,849 Posts
I believe that a dab of lithium-based white grease is a better lubricant for this particular application. I've used it for decades on all of our power antennas and never had a problem....
Old 12-20-2012, 02:49 PM
Gus's Avatar
Gus
Gus is offline
That may be true but the WD40 will clean the gunk that is preventing the full travel up and down.
oldjaglover
04-01-2020 05:04 PM
Presence
03-13-2016 02:21 PM
philwarner
01-31-2016 09:36 AM
Kaeghl
09-25-2015 12:49 PM
Quick Reply: Antenna travel
