antifreeze drain
So today I went to change the antifreeze in my car and when I pulled the drain plug nothing came out. Coolant level was fine and the temps been running ok around 204 degrees. So I stuck a small screwdriver in the hole and it was all gummy, I kept doing this wiping it off and doing it again. after 15 minutes of this I stuck a hose from a hand pump sprayer in the hole and forced water into the drain, after a minute or two it finally started to drain. I poured a chemical flush and will run that for a day and maybe do another chemical flush in a day or two. I hope it clears out the gunk.
sweez (07-16-2017)
