Any common transmission leak areas? Big puddle all of the sudden...
Have a look here
https://www.jaguarforums.com/forum/x...ion-oil-11374/
There's a connector that leaks.
Sentinelist (01-29-2013)
Have a look here
Jock itch powder, ha! I've heard of worse ideas, though I'll bet other similar powders would work too.
Sentinelist, I'd suggest getting the auto trans dipstick and checking the level (look for MB auto transmission 722.6 dipstick, such as on ebay). The connector "sleeve" is a common fail point, but I'd rule other fluids out first.
Do you work on the car yourself? I just rebuilt my valvebody a few weeks ago - if you have any questions on dropping the pan, changing the fluid, seals, etc just shoot me a message. Our early XKR's use the Mercedes Benz 722.6 5 speed trans - you'll also find plenty of helpful writeups if you venture over to the MB forums.
By the way, I highly recommend upgrading your shift solenoids to MB blue tops if you open up the valvebody. Shift quality is greatly improved and it brought my morning commute to a whole another level
Sentinelist (01-31-2013)
By the way, I highly recommend upgrading your shift solenoids to MB blue tops if you open up the valvebody. Shift quality is greatly improved and it brought my morning commute to a whole another level![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I generally always do my own work, but would rather never get under a car on jackstands out of a personal phobia of getting squished! It hurts my enthusiast creds, but I can't help it.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Note that they mention changing the pressure regulator spring, but that's not applicable in our situation (that's for MB 722.6's from I believe 95 and earlier). Everything else applies.
If you're already paying a shop to hoist the car and drop the pan, then consider changing:
1. The conductor plate (about $120, common wear part is the "speed sensor" which will result a "transmission fault" on our cars, you have to change the whole "plate" as the sensor is integrated. In my XKR this manifested itself as issues with shifting, and dropping to neutral especially when coming to a stop.)
2. The regular MB brown top solenoids to the MB AMG blue top solenoids, as already mentioned, for better shift quality and decreased lag between gear shifts (about $250)
3. The Sonnax Mercedes 722.6 Overlap valve sleeve kit - if you have rough shifts, especially 1-2 and/or when cold. I had shuddering in my 1-2 shift, especially when cold and going up hill, and this solved my issues. (about $50)
4. And the adapter sleeve, as already mentioned, and also mentioned in the MB thread posted above.
One caution on the Blue solenoids (for someone reading this thread), if you have a later series XKR they have the ZF tranny and they only work on the MB. Which is why I have two solenoids as paper weights, and $650 charge for someone to pull and take a picture of 6 ZF solenoids.
My srt8 would puddle passenger side
But yep, the leak is the connector. Fluid level is still OK (ordering dipstick today along with connector, will review that process in thread above), so I don't need to completely park it necessarily. I'll triple check my jackstands and do the work myself. I asked the tech for his thoughts on the solenoids and he just shrugged- "if it ain't broke, don't fix it" school of thought, of which I also largely subscribe to as well. He was aware of them, but didn't think they were necessary. I will keep these in mind though as the results sound encouraging.
Oil changed w/ 8 qts. of Castrol 5w30 dino, and said everything else looked great. In and out for well under $100? I can get used to this after my old Porsche would see multiples of that! *knocks on wood*
MC36
US Lower Atlantic
09-01-2015 07:34 PM
