Any Creative ideas? Lost locking pin for puddle light connector.
Hi Guys, I took off the passenger door card (the inner door pannel) and reached over to disconnect the puddle light's connection (the light in the lower outside corner of the door). This connection has a U shaped metal spring bracket, picture 3 sides of a square, that slips on and rides in a groove on the female connector. This groove is shared by the male connector on the door so when you mate the connectors, the shared groove is occupied by the metal spring bracket securing the connection. Bad luck, this time I was thrilled that I could get to move the bracket and looked forward to releasing the connector with just my fingers instead of hunting for a tiny screw driver, pow - it shot off into the void. It would be a miracle to find it now.
The connection opens so easily without the locking bracket, I don't think I can get away with omitting it. So now I've got to design something to secure it so I can put the door back together later tonight or tommorrow morning. The lost bracket is such a small guage that I don't think metal tie wire I have laying around would work. Might you have any ideas what I could substitute for this one? The best thing I can think of right now is to strand out a piece of copper speaker wire and try to wrap it around, but in my heart I don't think that will work because the groove the lost bracket rides in terminates before the bottom of the connection (remember I mentioned it was a 3 sided square - there is no "bottom" on the lost bracket, so the wrapped speaker wire will not ride in the groove).
I appreciate the brainstorming. Maybe one of you has run into this before.
If it doesn't hold look behind the fender on the drivers side, inside the wheel arch liner, on the back of the leaper badge should be the same connector which is for a side repeater which the US market does not use but the UK does..... Nick that one!
Don't ask me why but the righthand does not have one or is much more well hidden!
WhiteXKR (11-19-2014)
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
