Any ideas on this
Old 04-28-2016, 06:08 AM
graham11's Avatar
Default Any ideas on this
Hi guys,I've just noticed a very small Squeaking/Creeking sound coming from the o/s front suspension area,imagen the sound you would get if you twisted a new lether wallet so it's not a mitalic sound,ime thinking it may be a bush or one of the rubber components around that area,the drive and handling of the car is spot on,I only seam to get the sound at very slow speeds over uneven ground around 5mph or if i rock the car ,going to try some lube spray on the rubbers over the weekend but any ideas on what to check would be great,thanks
Old 04-28-2016, 06:33 AM
Ungn's Avatar
The upper wishbones have metal washers that bushing rubber can stick to, making a squeak.
It's probably time for All new upper wishbone bushings. This is a job anyone with tools can do.
graham11 (05-06-2016)
Old 04-28-2016, 07:23 AM
batroute's Avatar
May also be anti roll bar bushes or the top suspension mounts.
Old 04-28-2016, 09:23 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
My first thought would be upper wishbone bushes but there's several other possibilities in the suspension assembly.
I had an annoying squeak on the RH rear suspension of my XK which proved impossible to source just by inspection. We finally raised the RH rear of the body on an axle stand (leaving the normal load on the other three wheels), removed the wheel and raised then lowered the suspension assembly with a trolley jack until we found the one bush that was causing the noise at one particular point in the suspension travel.
Old 04-28-2016, 12:15 PM
Ungn's Avatar
I rebuilt my front suspension with new balljoints and bushings, and when I was bolting in the newly bushed upper wishbones, I noticed they squeaked when I moved them up/ down (they were still free and not installed into the hub assy).
I tore them back apart and saw there was old bushing rubber that had vulcanized to the large washers (not the smaller caster shims) that was the source of the squeaking. I cleaned the washers so they were shiny metal and applied grease between the washers and bushings and the wishbones were now silent.
It was very little material that was the sources of the squeaking, and since it was OEM bushing material, its very likely other cars would have the same problem.
Old 05-06-2016, 09:42 AM
graham11's Avatar
Well guys lovely day in the UK today so got stuck in and took your recommendations in hand,slackening off all the bushes and rubbers were poss and a good greaseing up did the job so let's see how long that lasts, if it starts again then it's a full renewal of the bushes on doth sides,thanks again for all your help.
Old 05-06-2016, 02:20 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
I was going to warn you of using a lubricant on your rubber bushings a few products will attack the rubber bushings causing them to have a short life. Lubricating your ball joints and universal joints is never a bad idea.
Old 05-07-2016, 04:24 AM
graham11's Avatar
Thanks gus I did just that mate and the lubricant I used was made for the job in hand.
oldish git
27
07-24-2020 02:05 PM
kenatofc
04-03-2016 10:42 AM
Lawrence
XJ40 ( XJ81 )
04-03-2016 07:20 AM
powerhouse
04-02-2016 02:55 PM
Quick Reply: Any ideas on this
