Any pointers on airbag light??
My 1997 XK8 convertible has the airbag light on, I do not get any blink codes, when you start car all is well with no warning lights, then within around a minute the light is on solid.
I have tried removing the battery to re-set but no joy also checked fuses all are correct size and not blown.
Any pointers before I have to have it checked by a dealer on the computer diagnostics?
That's rather uncharacteristic for it go solid w/o a blink code...and after a minute or so also. Last thread I read that had just a solid light was due to a total disconnect somewhere, where a short or a break in the path would cause a fault and blink code.
If you don't feel like trying to hung in and under the seat for a start, you're only option is the Dealer SDD software or find someone with AutoEnginuity. You can discover the same 'enhanced' manufacturer specific faults w/ ABS, SRS, and other modules in the same way.
Hi yes got a resolve, had it on diagnostics and it showed an undervoltage on the battery, it seems a 'module' checks battery voltage before it passes it on to the other computer systems, told the module would need to be replaced.
I had a flat battery some months before, it would not hold a charge so I fitted a new battery, had them re-set message at garage but not change the module... so far 1000 odd miles and no airbag light!!
Good luck... after all the money spent on my XK8 convertible with new battery and stainless exhaust.. I decided to sell so took it to auction... it made £2450 ... I was gutted,,, to the point I took her home.. now sitting on the drive waiting for me to do a couple of small jobs for MOT.
GGG (08-05-2013)
I found 3 things in my fault guide that may help you.
ON(light) B1317(sub code) Battery Voltage High Charging system
ON(light) B1318(sub code) Battery Voltage Low Charging system
ON Feed to Restraint Control Module Open Circuit/Short to Ground (unable to
communicate with module)
Fuse 10 (10 A) blown or missing - Driver Side Fuse Box. Connector: FC008
Hope this helps,
Hope this helps,
I hope you get a better price when you do come to sell the XK8.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
rsa760041
23
09-25-2015 01:33 PM
34by151
09-06-2015 05:14 PM
